1 - 19 of 19 Posts
I have Vostro1500 notebook.For the last few weeks system is very slow though >10-20% RAM is free and processor usage is also <50%.
I ran HDTUNE to check my HDD.
HD Tune: ST9160821AS Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 110 93 6 26535075 Ok
(03) Spin Up Time 99 99 85 0 Ok
(04) Start/Stop Count 96 96 20 4848 Ok
(05) Reallocated Sector Count 100 100 36 1 Ok
(07) Seek Error Rate 81 60 30 323403452 Ok
(09) Power On Hours Count 91 91 0 8331 Ok
(0A) Spin Retry Count 100 100 34 0 Ok
(0C) Power Cycle Count 96 96 20 4958 Ok
(BB) (unknown attribute) 24 24 0 76 Ok
(BD) (unknown attribute) 100 100 0 0 Ok
(BE) Airflow Temperature 56 40 45 840433708 Ok
(C0) Power Off Retract Count 99 99 0 3943 Ok
(C1) Load Cycle Count 1 1 0 214114 Ok
(C2) Temperature 44 60 0 44 Ok
(C3) Hardware ECC Recovered 67 52 0 181435599 Ok
(C5) Current Pending Sector 1 1 0 -1 Ok
(C6) Offline Uncorrectable 1 1 0 -1 Ok
(C7) Ultra DMA CRC Error Count 200 171 0 12853 Ok
(C8) Write Error Rate 100 253 0 0 Ok
(CA) TA Counter Increased 100 253 0 0 Ok
Power On Time : 8331
Health Status : Ok
How do i interpret these results?
Plz help.
thanks
waris
AMD Fangirl
Your drive has a bad sector. This is usually a warning that there may be problems with the drive itself. I personally replace any drive with even 1 bad sector.
Run MHDD to scan the entire surface. As it doesn't run through Windows, any driver issues or related won't affect the scan.
Probably sleep deprived
One bad sector isnt especially worrying, just so long as you continue to monitor and make sure you dont suddenly see an increase in bad sector count.
Run a full Error Scan of your hard drive in HDTune and report back.
There is a pretty good chance something is eating up processing power or HDD i/o if the error scan comes back ok.
What web browser do you normally use and have you scanned your system for viruses/malware recently?
Hi,
replaced the HDD with Hitachi ZK500
Here are the results..
HD Tune: HGST HTS545050A7E380 Health
(01) Raw Read Error Rate 100 100 62 0 Ok
(02) Throughput Performance 100 100 40 0 Ok
(03) Spin Up Time 230 230 33 1 Ok
(04) Start/Stop Count 100 100 0 13 Ok
(05) Reallocated Sector Count 100 100 5 0 Ok
(07) Seek Error Rate 100 100 67 0 Ok
(08) Seek Time Performance 100 100 40 0 Ok
(09) Power On Hours Count 100 100 0 11 Ok
(0A) Spin Retry Count 100 100 60 0 Ok
(0C) Power Cycle Count 100 100 0 13 Ok
(BF) G-sense Error Rate 99 99 0 65537 Ok
(C0) Power Off Retract Count 100 100 0 3 Ok
(C1) Load Cycle Count 100 100 0 253 Ok
(C2) Temperature 157 157 0 1441830 Ok
(C4) Reallocated Event Count 100 100 0 0 Ok
(C5) Current Pending Sector 100 100 0 0 Ok
(C6) Offline Uncorrectable 100 100 0 0 Ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
(DF) Load/Unload Retry Count 100 100 0 0 Ok
Power On Time : 11
Health Status : Ok
How does it look.
Definitely an improvement
AMD Fangirl
Are you running in IDE mode (as configured in BIOS for SATA controller)? That may explain those dips in performance and high CPU use.
It looks like you're running XP, and if so, you need proper drivers and some registry tweaks to switch to AHCI. The performance improvement is well worth the effort.
The HD Tune results look OK. Has the performance of the system gone back to where it was? If it has, then you probably had a failing HDD. One bad sector doesn't necessarily mean the drive is in a death spiral, but I never take chances either. I go so far as to replace mechanical HDD's after a year or two of service even if they test perfectly normal. They're not that expensive, and restoring data from backups is a bigger PITA than just pre-emptively replacing the drives.
AMD Fangirl
Originally Posted by mt0010 View Post
Can somebody interpret my SMART info, too, please? Thank you in advance.
Looks like a healthy drive to me.
AMD Fangirl
Try using CrystalDiskInfo to read the values, and see if that is the same high value.
Command Timeout can be due to a lot of things....oxidized/bad SATA cables, controller issues, power issues.
If the value isn't increasing, and you aren't having performance degradation, I wouldn't sweat it.
AMD Fangirl
I say it looks ok to me.
Windows Wrangler
this is what I got:
anything unusual? thanks!
Yes, I would keep an eye on the value you have selected (Reported Uncorrectable Errors), which should be 0 but went from 10 to 12 (hex A to C) in the short timeframe between your two screenshots. The HDD's normalized value for that entry confirms that the number is heading out of spec, since it should be 100 but has declined to 88.
In addition, End-to-End error is out of spec; it should be 0, but it is 57 (hex 39); and its normalized value is officially in SMART fail state at 49 when the threshold is 99.
i'm particularly worried about the command timeout, is that normal. I mean, it's in billions. thanks again!
I can't say it's normal, but the HDD thinks that number is OK since the normalized value for that entry is 100, so I wouldn't worry about it.
Are you having problems with this HDD?
I'm not sure if this is related to the hdd but I've been getting tons of event 153 (1,500+ in total since I've got this laptop 4 months ago). Just earlier this morning, I had a dpc watchdog violation bsod and after that, checked event viewer and found hundreds of event 153. I'm not sure if that's an hdd problem.
To add to that, I've had a few instances when it would just freeze up during boot (logo with dots spinning in circles) and I would hear a sound that seems like the hdd just stopped spinning.
Thanks for the reply!
Data Recovery Engineer
I have had a drive with 2 bad sectors cause all kinds of awfulness... If there is even a single bad sector it is time for replacement.
1 - 19 of 19 Posts
