have you tried using http://speakeasy.net/speedtest
I generally get more accurate results when using their test.
Also don't know if dsl is the same as cable but if it is you
may be able to get some insight into a possible solution by
accessing teh modem through http. You will have to know
the brand and model to find the access url.
If it is similar to cable you will se some details on your connection quality
which you can search for their names and see what is good and what is not.
most modems/routers use 192.168.1.1 for access.
