1 - 3 of 3 Posts
Hello, I'm planning a build out using the SMA8-A, and I'm curious if there's any room in the 39mm Top to run 1/2 inch soft tubing that would connect to a Pass Through connector above the motherboard chamber? This is assuming Fans are also in the top chamber, with a Radiator in the motherboard chamber below. It looks like it might be possible to run them from the back of the case into the top, possibly with an additional hole tapped, but want to confirm.
Thanks!
Discussion Starter #2
WaterCooler & Overclocker
1 - 3 of 3 Posts
