1 - 10 of 10 Posts
Switched to an i7 platform and for the most part I am liking it. Running a gtx360 rad with 12 fans in front. I have a little more re-organizing to do. I might take out the window fan and put in the screen so I can mount the res properly with the panel on. I'm now running full 1/2 inch tubing as well.
Sorry, crappy pics.
Originally Posted by unleaded91 View Post
Nice setup!! What coolant did you use?
+rep!!
Very simple. Distilled, a couple caps of water wetter (I used to be into cars) and a little food colouring to darken the red. Oh and thanks for the reps.
You're welcome!!
Okay cool!! Thanks!!
12 fans?!?!
Originally Posted by thehighlander123
12 fans?!?!
I was waiting for someone to say something. I already had them as the rad was mounted on the outside of the case in a push/pull. So I thought that instead of spending more money on fans, I'd just use everything i've got. A little experiment of sorts. 2 are already dead though.
Originally Posted by Monkey92 View Post
Very slick, although that coolant looks like cough syrup
I like to think of it as the blood of the system.
Originally Posted by 006 View Post
what kind of temps do you get ?
The measureable kind.
Idle, cores sit between 25-30C and hit, but never exceed, 60C under load with small fft's. That's 4.1GHZ 1.42vcore.
1 - 10 of 10 Posts
