small vista upgrade issue
304 Views 4 Replies 3 Participants Last post by  BURNS331
trying to upgrade from xp mce 2005 to vista home premium and it says that there's an incompatibility with messenger live being installed and cant upgrade.
I dont think messenger live is installed, only the original version of msn is there and that's because i don't use it.
How can i uninstall msn live? I checked the uninstall list and it wasnt there to uninstall in xp.
Does Vista want me to install it instead?
I know these are dumb questions but im kinda stumped, just looking past the obvious.
Thanks guys
1 - 5 of 5 Posts
Its messenger 5.1 not live, still no idea where its at, because i dont have the option to get rid of it
There is a way yo can get rid of it:
Click on Add/Remove Windows Components and you can remove MSN Messenger. There is two services to remove everything.
http://www.tacktech.com/display.cfm?ttid=288
The upgrade process can be a huge pain and it might serve you better in the end to just back up all of your data and build a fresh vista partition. Just my 2 cents.
i just pushed threw the issue and now vista is intalled, thanks for the help. Not sure why the update issue threw a code.
1 - 5 of 5 Posts
