1 - 3 of 3 Posts
Just got new RaptorX 150gb and<br />
In speedfan:<br />
Spin retry is 11 with a 51 threshold...<br />
And in Diskkepper i get a Warning:<br />
-The MFT usuage is currently 99% of the total MFT sizewhich indictaes it is likely the MFT will become formatted<br />
<br />
Can anyone help me understand all this? And what i need to do, do I need to send it back?
the spin retry count started at 200, its at 11 meaning you drive has failed. Because SMART says it is you should be able to get it replaced. Sorry dude, your drive is ****ed. Happy RMAing.<br><br>
Cheers
Administrator
Well this does usually mean that the Drive has failed unfortunately. Are you getting any other system symptoms.<br><br>
Also in Diskkepper you can resize and defragement the MFT file so i would give that a go along with a Boot defrag.
1 - 3 of 3 Posts
