The board came from Ebay and had a few bent pins of which I am satisfied are fixed otherwise I don't think it would boot at all.
The cpu came from an ocn member in trade. Windows installed fine but the system is extremely sluggish. Cpuz reports 2.1 ghz. Occt hangs at the splash screen. LinX fails on the second test at around 7 minutes. Is there something I need to do in BIOS? C1E AND EIST are off.
Is the system too hot? Also check for bad/leaking capacitors - this will cause sluggish performance.
Also there is 1 or 2 more options in the bios that should be disabled - one regulates the multiplier based on thermal conditions and the other regulates vcore based on thermal conditions. (I think
Overclock.net
