My itrip has been extermly low signal quality, and i just got fed up with it. I decided to find a new antenna. No pics of building, but it was my first time using a soldering iron, so it seemed to work. I just used an old telephone wire, and striped off the cables. You could easily use any cable that you wanted, but thats just what i had lying around.
if its effective, good job. if not, theres a calculator somewhere for how long antennas should be for max effectiveness given the signal theyre putting out. might help.
I took an entire length of a telephone wire and stripped it. TBH, any length is better then the origional, but im open to any calculator. I havent found a dead spot yet in my house, including from the very back, to the front of the driveway. Its pretty powerful
Overclock.net
