flash memory in general is only rated for so many reads and writes over it's lifetime. You don't have to worry about performance degradation really unless you are writing hundreds of GB's of files per day. The intel IIRC, is rated for 20 years or so with normal usage. If you figure you will most likely replace the drive within 2 years, you need not worry at all. In 2 years SSD prices will have come way down in price per GB. Especially with Trim, which is supposed to improve performance up to 40% and also completely erase all blocks written to the SSD that isn't removed the first time around. Windows 7 will automatically TRIM, but you can download the intel toolbox that I posted, just look for "Download Intel SSD Toolbox Here:" in this section. You can run TRIM manually with it, and schedule it to run when at a certain time on a daily basis. The reason you will have to get it from me is that intel temporarily removed the download from their website and nobody is sure when they will repost it.
Hope this answers some/all of your questions.
