1 - 8 of 8 Posts
Hey<br>
Having decided to completely rebuild my computer i ran into a problem. AGP or PCI Express? i realize that PCI Express is better but could i get more bang for the buck out of an AGP card? I have a budget of about 400-500 for a graphics card since i'm gonna use my old CPU. What i know i want so far is something with 512Mb of memory and that i'd really like to have it be ATI. If anyone could recomend a good card that would be great.
I TeK things...
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814102045" target="_blank">http://www.newegg.com/Product/Produc...82E16814102045</a><br>
that should suit you nicely then....if you go PCIe....and yes you will get better bang for the buck with PCIe....
no wai<br><br>
7900gto<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814130065" target="_blank">http://www.newegg.com/Product/Produc...82E16814130065</a><br><br>
or<br><br>
x1900xt 256<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814102051" target="_blank">http://www.newegg.com/Product/Produc...82E16814102051</a>
The 256mb x1900xt may restrict things a little at higher resolutions<br />
<br />
I would go for the x1900xt 512
definitely go for pci express
Discussion Starter #6
Pretty....<br />
ya so i'm liking that Sapphire X1950XTX, i mean if i ever <i>did</i> get greedy i could use the Crossfire <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> . <br />
definately PCI Express then, i just really needed to figure out a gameplan for what i needed for a mother board.
PCI-E!!! GEt a x1900xt something(i dunno about ATI) Or a X1950XTX. There's a....copied from other thread. Sapphire Toxic X1950XTX<a href="http://www.hardwaresecrets.com/news/1531" target="_blank">http://www.hardwaresecrets.com/news/1531</a> for $474.99 at Tigerdirect.
Discussion Starter #8
I just was reading about the Toxic on the Thermaltake website and it seems awesome. Can you link to it, i can't find it on Newegg or Tigerdirect
1 - 8 of 8 Posts
