That "Bare" paint you linked is graphite based and can NOT be used as a shunt resistor--the resistance will be too high. It can be used as a conductive adhesive to "stack" shunts without soldering (due to resistance affecting the stacked shunt effectiveness, I would go no higher than 5 mOhm shunts for stacking with that), on a board that has the original shunts "flush" and "flat" (middle black part being slightly below or the same elevation as the silver edges, but NOT ABOVE the silver edges!), but I have not tested that. Definitely not for shunts that have depressed edges due to issues getting proper contact--use MG842AR instead. In general, use the MG842AR for both its own shunt (painting the entire shunt fully, completely) or for shunt stacking.
On boards that have shunt edges depressed below the middle housing, you may have contact issues getting the paint applied properly. Make sure you use protective super 33+ tape!!
On some boards you will need to scrape the edges of the shunts (the silver part) with a small flat blade to remove the conformal coating--this is required for proper contact with the paint.
No risk of dripping it on the PCB if you use this.
Perfect for paint protection. Peels right off without any risk to components.
If you are soldering shunts, use high temp Kapton tape to protect your PCB instead.
