I fire up my board (had it for almost two years) after major work on it to put water blocks on it and I get the power LED's, I get the video cards and fans to pop on, I get everything except a boot sequence. No boot...no LED error code read out...no beeps.
Afterwards I replaced all the detachable components (PSU, RAM, Vid Cards, fans, external connections, battery, etc) except the i7 920 chip, even removed it from it's case and tried a cardboard box test build, and still no go.
I'm sure I bunged it up when I put on the NB/SB water blocks (worked before...didn't work afterwards) but what do you think actually happened? Did I break a connection under the board when I tightened the screws on the blocks? There's no visible damage...there's no water damage...first time in over 10 years of DIY PC work this happened and without knowing details I must have shorted something. Any chance it's the chip?
I ordered a Asus Rampage III Formula (want to reuse i7 and RAM chips) so hopefully things will go well w/that once it arrives but I loved that X58 board...it was a dependable OC machine...sniff, sniff...
