1 - 8 of 8 Posts
just a random question peoples
wondering if a could drop a 8700K in my Z270 motherboard if I wanted to
just curious,,i would need a bios update though
Avid Memer
Coffee Lake is not compatible with 200-series chipsets. You would need a 300-series motherboard.
Avid Memer
Hacking the BIOS and adding microcode won't help because the pins are different. The incompatibility is because of hardware, not software.
The pins aren't different, the "new" 1151 just has additional voltage pins. Signaling pins are identical. Coffee Lake engineering samples were used on Z270 motherboards. It has essentially been called a firmware lockout because lower end Z170/270 boards may fail to provide adequate power.
So yes, BIOS hacks could enable compatibility.
Avid Memer
However you want to cut it, they're incompatible. Coffee Lake has fewer reserved pins.
The "fewer reserved pins" are EXCLUSIVELY power delivery. Coffee Lake was used on older LGA 1151 sockets during development then locked out by firmware due to some motherboards being unable to provide sufficient power without those additional pins.
If the lockout is related to firmware and not signaling, it can absolutely be hacked to allow for compatibility.
That doesn't mean Coffee Lake will run properly on a $90 Z270 board - or any Z270 board for that katter. It only means that Coffee Lake's signaling is identical to all other LGA 1151 CPUs.
Discussion Starter · #8 ·
well that answers my question peoples,,thank you
1 - 8 of 8 Posts
