I've used the search function, but didn't find anything on the status of the socket burn issue. So, has the 1156 socket burn issue been solved with the current revision of the various boards, or is the root cause of the problem still unknown? Is it due to the certain socket manu (Foxconn/Lotes) or inherent design issue with fewer power pins compared to socket 1366? What's the status on this right now?
I want to buy the i7 860 instead of spending even more for i7 920/x58, if the socket issue is now solved.
Thanks
Thanks
