1 - 6 of 6 Posts
I've done some search, but not too many places has posted LGA775 Prescott temperatures. So let's gather some info on how hot LGA775 could be. It'd be informative too if we can compare those with 478 ones
To help please use the following template
Speed (Ghz):
Socket:
Idle Temp(C):
Max Temp(C):
Mobo Idle Temp(C):
Mobo Max Temp(C):
Cooling Solution:
Case:
No of Case Fans:
Mobo:
Monitoring Software:
Discussion Starter · #2 ·
My setting:
Speed (Ghz): 3.2 Ghz overclocked from 3.0
Socket: LGA775
Idle Temp(C): 45
Max Temp(C): 52
Mobo Idle Temp(C): 20
Mobo Max Temp(C): 21
Cooling Solution: Kingwin AWC-1 CPU+VGA water block
Case: Antec full tower
No of Case Fans: 2 front, 1 side, 2 radiator
Mobo: Asus P5GDC
Monitoring Software: Asus PC probe
Speed (Ghz):3.4 OCed to 3.85+
Socket: 775
Idle Temp(C):40
Max Temp(C): 47
Mobo Idle Temp(C): 32
Mobo Max Temp(C): 45
Cooling Solution: TT 112 w/ 2 80mm 40cfm fans
Case: TT xaser 3
No of Case Fans: 7+2 modded on(kinda)
Mobo: Abit Fatal1ty 925xe
Monitoring Software:OCguru
From what I've seen, LGA775 have been running cooler and clocking higher. While my temps aren't really for throwing into the comparison, under a 226w TEC and the same water cooling system, load temps were ~30C. W/ a BIX instead of the heater core and a 226w TEC, load temps were ~45C.
Socket: 775
Idle Temp(C):40
Max Temp(C): 47
Case: TT xaser 3
do you have anything to hold up your tt112 or the mobo is strong enought o hold it up cuz i no that thing weighs a ton
1 - 6 of 6 Posts
