1 - 20 of 26 Posts
got a 2600+ t'bred but its running at 51 degrees. thats at stock. i'm wondering what would be the best aftermarket cooler?
This thermaltake looks nice:<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835106035" target="_blank">http://www.newegg.com/Product/Produc...82E16835106035</a><br><br>
Or this one:<br><a href="http://www.frozencpu.com/products/4104/cpu-scy-05/Scythe_Katana_CU_Dual_Heat_Pipe_All_Copper_CPU_Cooler_SCKTN-CU1000.html?tl=g40c14s50#blank" target="_blank">http://www.frozencpu.com/products/41...40c14s50#blank</a>
wisperRock II<br><br>
simply best/cheapest skt a cooler<br><br>
and you can add any 80mm fan you want.
the ABSOLUTE best SKT A Cooler is the SP-97. It is discontinued, but you can find it usually on ebay or in the near future on the forums (hint)
ROFL... when is near future <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
heh chozart, i cant say anything here, but if you pm me, ill let you know. <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br><a href="http://www.thermalright.com/a_page/main_product_sp97.htm" target="_blank">http://www.thermalright.com/a_page/m...oduct_sp97.htm</a><br>
Thatssss it! If you put a 92mm Tornado on it like i did before, i got up to 2.5ghz @ 48c Load. Insanity!
Check out <a href="http://www.thecoolingshop.com" target="_blank">www.thecoolingshop.com</a> for SKT A Cooling
Discussion Starter #8
cheers guys. i'll shall have a look.
The TT Big typhoon also fits socket A
Old school
51c on load is very low already for a socket A. They can easily take up to 65c under load.
As long as its stable then its not really a worry.<br><br>
I have got a amd laptop with same cpu as this one in and it hits 90c under load!!
Discussion Starter #12
90!!!!<img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> u gotta be kiddin' me! that nearly as hot as me kettle.<br>
i knew skt A could take more heat but wasnt sure how much more. think i'd be a lot happier if i dnt see 60.
Freaked me out a bit too!!! Idles at about 60c too unless powernow is enabled then it drops to around 40c<br><br>
The mobile chips are tougher though and can take the heat more. It runs at 133x14 and proves its not a worry as long as its stable. Saying that i have seen my mobile in desktop get unstable above 50c but thats cos its running ocd at 225x11.
send images i don't beilve it your probe must be messed up, the chip MELTS at 95
double post sorry
max temps for a mobile one is 95-100c according to amd site. If you dont believe me and i do send images you wont believe them will you? but here they are any way. Apologise about the girly desktop as its the wifes laptop!!<br><br><a href="http://img342.imageshack.us/my.php?image=1hw7.jpg" target="_blank"><img alt="" src="http://img342.imageshack.us/img342/6729/1hw7.th.jpg" style="border:0px solid;"></a><br><br><a href="http://img342.imageshack.us/my.php?image=2lt2.jpg" target="_blank"><img alt="" src="http://img342.imageshack.us/img342/7426/2lt2.th.jpg" style="border:0px solid;"></a><br><br>
edit: was doing a memtest run to test new ram and it kept shutting down. I guess it was hitting 95c and shuting down automaticaly. Maybe time to open it up and clean the dust and AS5 it!!!
I used to run a V12 on my old xp-m 2500 and it was kind of loud at high flow but it did the job quite well.
oops; hit the refresh button.
Aero7lite>Coolermaster
I have a stock Akasa with 60mm fan on an unlocked 2600+ and its load while folding is 48°C
1 - 20 of 26 Posts
