So I've found the CPU that I've been looking for (i7 720qm) but I've had absolutely no luck finding a motherboard or gpu for it.
Where would you guys go about buying the motherboard? And can you buy the GPU separately from the motherboard, or are the GPU soldered onto the motherboard? (in the laptop world)
Please, don't tell me to give up looking, I'll ignore that post and file you under the category of, "Ignore what this user says".
If you're willing to help, great! If not, please don't waste bandwidth.
