1 - 20 of 46 Posts
I know theres been threads about this, but none of the software ive tried so far has actually made my computer any faster, if anything its just slowed it down..
I would like a software that can:
Speed up general use (e.g. chrome opening time)
make logon faster
automatically delete rubbish you do not need
defrag/clean up your computer every day or week etc..
thank you.
Filthy Casual
You can try this http://www.iobit.com/gamebooster.html IDK how it improves normal programs but it works with CPU heavy games if you have your system bogged down with start-up entries and background apps.
W7 automatically defrags your HD unless you set it not to. Ccleaner can delete unneeded files and clean your registry, and you can set it to run on a schedule if you want. If you installed your OS on a SSD that would speed everything up a lot.
Filthy Casual
Cleaning the registry is not recommended. But the Speccyand and Recuva functions of Ccleaner will help
Reactions: jdcrispe95
But beware. Lots of services and programs that you need for your daily use would be shutdown. So it won't really work.
Best thing is to manually stop startup programs and stop services that you don't need.
Manually disable Services that you know you don't use...I wouldn't recommend it if you don't know what you're doing. Msconfig...you can uncheck startup items you don't use as well, but same as what I stated above.
Otherwise, another vote for Ccleaner.
Filthy Casual
Right-O chap... just a suggestion
Just type msconfig in the old start box of your windows start menu (or "Run" box) and you have all most manual startup options at your fingertips.
I dont know anything about the services with windows 7, things I could end on XP, I cannot end on 7, otherwise things mess up (like aero, or my internet, or audio)
Thanks for all the input so far, I am downloading CCleaner now, I will look into boostspeed.
I know you're probably looking for something free but all of the things you are wanting to increase speeds of are your hard drive performance. If you want to see performance increases on the level of near instantaneous then get a cheap 32 GB SSD for your OS+main apps.
60GB Agility2 $90 AMIR
Discussion Starter · #16 ·
SSD's are not available in my area.
I can pay for software if its a MUST.
Thank you so much for all the input so far guys, i have done all the things you've suggested so far, Ive scanned/defragged/disabled services/stopped startup items etc
I will rep the people who deserve it.
Filthy Casual
Agreed, http://www.newegg.com/Product/Product.aspx?Item=N82E16820167030&cm_re=intel_SSD-_-20-167-030-_-Product is really cheap now. It's what I have in my sig rig and I love it
Originally Posted by jdcrispe95;12056956
Ccleaner:
CLEANING COMPLETE - (6.804 secs)
185.2 MB removed.
Good
Getting there
Like 185.2MB matter.....
The Computer Guy
make logon faster
thank you.
this is a very good cleaner http://www.auslogics.com/en/software/boost-speed/
it's what i use.
1 - 20 of 46 Posts
