Soldam Windy Super Silent 120mm Fans
2089 Views 33 Replies 15 Participants Last post by  Mmansueto
Soldam Windy also makes fans. Their SS (Super Silent) series are simply amazing. They compare very well to the Noctua NF-P12-1300 120mm. Comparing them side by side, they are very close to the same noise level. The Windy SS has a lower hum than the Noctua.
Specs:
1000RPM-18.7dB-38.8cfm
1200RPM-24.0dB-44.7cfm
I will have more details on them later. I am currently looking into purchasing a large quantity of them and shipping them to the US. If there is enough interest in them, I plan to go though with it. I can get pricing information in the future.
1 - 20 of 34 Posts
Any idea on what bearings they use?
those would prolly be good rad fans.
not bad, any specs on the bearings and such?
I wonder if they are rebrands of another company...
EDIT: dam Marin beat me
I'm not sure, but I will look into it. Anyone know Japanese? The have text in images on their site so I can use Google translate for all of it
Yeah, MMansueto said he was using them for his rig right now.
Coming from Soldam, I doubt it is a rebrand. I will look into the technical specs.
You can send me one and I'll pop it open
im serious though... seriously... =p
I'd be up to that. I'm looking but don't see any real technical data on these fans. PMing you
I am japanese. Send me a message and I will help you.
PMed
Thanks to Minamoto, I found some more info. There is the SS Premium model. They are double ball bearing. They are amazing, 17dB, 60.95CFM.
I am not planning on getting any of these.
The model in post 1 would be $10-15. I have to get more details before I can set a final price.
17dB, 60.95CFM?? that's amazing if its true, id buy one of those!
$10-$15?
Sounds pretty good even if you don't know the final price.
I'd definately be interested. I need some new fans...
Someone needs to find out how accurate this is first-hand. That DOES look amazing.
Edit; converted yen to dollars for them, that's ~$75 per fan. That's without the dust filter kit. Are they so confidently crazy in their own ratings that they make San Aces look dirt cheap just to make you think it's that accurate?
Mort, I would be interested in one of these if the price is under $20. If they meet my standards for noise I will take a couple more. These Slipstreams are wearing out and Noctua refuses to send me free fans
Wow, those fans are ridiculious, but WOAH $75 per fan...no even Soldam
First don't believe manufactures stated rating, they can measure db's at any range from the fan they want (noctua's and silenX are good examples).
Second, these fans are made by Cooler Master. Pack of four for cheaper than one rebranded fan.
http://www.newegg.com/Product/Produc...82E16835103052
Have Fun
To give everyone an idea, i replaced all my yate loons with these. I have 25 of them right now. I paid far less than $15 US per fan. I am looking into bulk pricing on them. I am waiting for my distributor to check in on them. I will pm Mort with more details later. Marin, pm me if you want one to test out (i have a bunch of extra)
1 - 20 of 34 Posts
