1 - 16 of 16 Posts
· Banned
Hey guys, I've been looking at ditching my GTX480. What would you recommend as a solid upgrade? Basically I'm sick of the power requirements, heat, and noise from the 480 so I'd like something much more efficient yet capable. I've got a Corsair 750w PSU and would like to keep costs around $300 if at all possible. I game at 1080p. Was thinking possibly a GTX660??
· Premium Member
For $300 I'd highly recommend you go with an AMD Radeon 7950. If you want to stick with Nvidia then you can get the MSI 660 Ti power edition for $300 which is the best 660 Ti.
I went from a GTX480 to a HD7970 Lightning. Could not be happier. 7950 isn't that far behind the 7970 so!
· Premium Member
· Banned
Discussion Starter · #11 ·
Originally Posted by AndyM95 View Post
Go with this instead:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
It's cheaper, a better card and you still get the free games
I looked at that one actually and I couldn't really tell the difference aside from the cooling. Spec wise they appear the same. Plus no 10% off the Sapphire. Why do you think it's better? I would think that particular card would do a poorer job of pushing warm air out of the case? And be louder?
· Premium Member
The Sapphire is 9% off (usually $319.99) and it has a dual fan cooling setup which will keep the card cooler. Both use designs very similar to reference so the PCB isn't any different, just the cooling setup.
· Banned
Discussion Starter · #13 ·
Hmm decisions, decisions. Thanks!
· Banned
Discussion Starter · #15 ·
Well I thought about it all day and it was still in stock at Newegg so I pulled the trigger on the Sapphire 7950. The cooling solution seems like it'll be better/quieter. Thanks for all the inputs!
· Zeon
You won't regret it
1 - 16 of 16 Posts
