1 - 20 of 34 Posts
· RIP OCN 2018
Hi,
I have a new rig.
2500K stock
6950 not unlocked CF
4 GB ram
64 GB C300
etc
Most of my games don't want to install or run.
I've tried COD 4 , 6 , any many more. these crash on starup
BF BC 2 isn't stable as well ( i know other people have this issue as well )
All Drivers are latest version.
I want to start gaming on this thing?
Do I really have to sell my ATI cards first and buy Nvidia?
Or how do I fix this?
Grtz
Xioros
CoD4 problem: plug in a mic.
· RIP OCN 2018
Changing sig
I'm using the Logitech G35
EVERYTHING STOCK
Games do install,
But Instandy crash on startup
· RIP OCN 2018
Discussion Starter · #8 ·
I'll run memtest to be sure,
Already tried to disable CF,
Do I have to pull a card out?
And what's the point?
I bought this cardSSSSS, i'm not playing with one?
grtz
xioros
· Premium Member
did you install the latest caps also with the latest drivers.
· Premium Member
grtz
xioros
Quit being so damn stubborn! Take a step back and breath dude! This process is called TROUBLE SHOOTING! Run mem test. Stress test the cpu. Remove one card. Keep trying. Obviously something isnt working right! Were trying to help you figure this out. If you wanna ***** and moan about your non working rig, then go complain to bestbuy noobish geek squad and pay them $200 to do it for you.
Just be patient. We will eventually help you find a solution. So far all we know is its not working. But why? Run through these steps and we can narrow it down!
Nicely said, but yeah if you want us to help you, quit the stubbornness. Listen and we can help you get this issue sorted. Have you also removed any drivers If so, did they remove properly? Use driver sweeper, and clear all drivers then try re installing, if the above options didn't work.
· Padawan Overclocker
Uninstall drivers, turn off pc. Remove 1 card. Turn on pc. Install drivers. Check if the games run. Do this for the other card too.
· RIP OCN 2018
Discussion Starter · #14 ·
OS is legit, games are legit
Memtest doesn't want to boot of my usb --' and I ran out of CD's yesterday...
So, Use driver sweeper?
I'm going to reboot with one card
Brb
PS: I didn't mean it like that
· RIP OCN 2018
Discussion Starter · #15 ·
driver sweeped
Reinstalled
Now every is *ed up.
Driver doesn't even seem to work
what now?
· RIP OCN 2018
Discussion Starter · #17 ·
not yet, i'm trying an other driver now
· RIP OCN 2018
Discussion Starter · #18 ·
installed the 11.4 beta driver.
This one worked
games still WON'T work...
any more suggestions for a fix?
Now trying the other card
1 - 20 of 34 Posts
