Hello,
I am having a nightmare with BSOD's while the CPU is on idle, but it only happens after a few hours of being asleep, I wake up to find the computer has BSOD' after a couple of hours of idling on the CPU ([email protected] on the GPU's).
Here's my OC settings for 4.7GHz:
What do you guys think? These BSOD's are driving me nuts, I can run Prime 95 on 1344 or 1792 FFT's for over an hour just fine but it just gives a BSOD at night... Funny is the CPU is on idle, only the GPU's are being stressed with [email protected] at night, and Battlefield 3 is minimized as I idle on my own server to keep it filled 24/7.
Also, here are the last 2 mini dump files created in the last 2 BSOD's I got:
http://www.mediafire.com/?ak3j36zgdlc5392
Sometimes it's 9C BSOD, sometimes 124, and sometimes 101...
Any help would be appreciated. Last change I did this morning was boosting VTT and VCCSA from ~1.180v to ~1.190v and also the CPU Vcore Offset Voltage from +0.040 to +0.045 to see if that gets rid of the idle BSOD's... Although I don't see how more vcore would help for idle since I can easily run Prime 95, [email protected] or gaming without any BSOD's.
Edit:
The issue is definitely fixed, looks like disabling C3/C6/C7 on BIOS helped get rid of these idle BSOD's!
Big thanks to $ilent and CloudX for suggesting it!
Edit:
