I uninstalled the catalyst suit as I assumed I was having problems with my BC2. Went to 10.3s, lost a few features, and then tried 10.9 again. Started getting my BSOD on BC2, so I decided to uninstall the drivers again and reinstall 10.9. And did so, successfully after a restart.
Now I lost my raid-1 drives...again. They are completely undetectable in windows. Before I had to format the drives in windows in order for them to be detectiable. Now they aren't showing up at all.
Anyone got any ideas on how to get my raid-1 drives back? They are showing up in bios as a raid-1 array. I can't do a system restore (worked last time) as for some reason my C drive just won't let me restore. I'll check system restore now. Nope, only has the one I had to make up to hopefully do something. :/
Thanks for any help.
Alright, turned the raid settings to ACHI and they are recongized again.
Alright so it turns out the drives were recongized but now they are reading as a raid-1 drive ._.
Any ideas?
edit: alrigth solved. new drivers did the trick.
Any ideas?
