1 - 14 of 14 Posts
Do i need to flash the bios, and if so what bios is unlocked?
If not is there something i dont have set up correctly with afterburner? I tried trixx and it doesnt work with my card.
my 6950 goes up to 13xx
is your config set right? no need to flash your bios.
it's reference right?
yes its a reference card. im not sure about the config what specifically do i need to set?
heres my config for ab
[Properties]
ShowGeneralTab= 1
ShowFanTab= 1
ShowMonitoringTab= 1
ShowOnScreenDisplayTab= 1
ShowScreenCaptureTab= 1
ShowVideoCaptureTab= 1
ShowProfilesTab= 1
ShowUserInterfaceTab= 1
[Settings]
Skin = compact.usf
StartMinimized= 0
StartWithWindows= 0
RememberSettings= 0
FirstRun= 1
FirstUserDefineClick= 1
FirstServerRun= 1
HwPollPeriod= 1000
MMIOPageSize= 4
PCIBusFilter= -10h
ShowTooltips= 1
ShowHints= 1
PauseInSuspendedMode= 1
CurrentGpu= 0
Sync= 1
AttachMonitoringWindow= 1
MonitoringWindowOnTop= 1
ShowPerformanceProfilerStatus= 0
LCDFont= font4x6.dat
LCDScrollTimerPeriod= 30
UnlockVoltageControl= 1
UnlockVoltageMonitoring= 1
ShowOSDTime= 0
RestoreAfterSuspendedMode= 0
StartupViaTaskScheduler= 1
StartupDelay= 0
MinMonitoringGraphHeight= -1
LocalizationDebugFlags= 0
EnableLog= 0
RecreateLog= 0
LogPath=
DontStopLoggingOnWriteFailure= 0
LogLimit= 10
ForceConstantVoltage= 0
AllowCaptureVoltageDefaults= 0
Link= 1
UseDirectInputHotkeyHandler= 1
SendToTrayOnClose= 0
DataFilteringThreshold= 10
ScreenCaptureFolder=
ScreenCaptureFormat= bmp
ScreenCaptureQuality= 100
VideoCaptureFormat= MJPG
VideoCaptureFolder=
VideoCaptureQuality= 85
VideoCaptureFramerate= 30
VideoCaptureFramesize= 2
VideoCaptureThreads= FFFFFFFFh
FanSpeedReadbackDelay= 1000
CaptureOSD= 1
AudioCaptureFlags= 00000003h
[ATIADLHAL]
UnofficialOverclockingEULA= 1
UnofficialOverclockingMode= 1
AccessibilityCheckingPeriod= 0
[NVAPIHAL]
ClockDomainIdWorkaround= -1
[Properties]
ShowGeneralTab= 1
ShowFanTab= 1
ShowProfilesTab= 1
[Settings]
Skin = compact.usf
StartMinimized= 0
StartWithWindows= 0
RememberSettings= 0
FirstRun= 1
FirstServerRun= 1
HwPollPeriod= 1000
MMIOPageSize= 4
PCIBusFilter= -10h
ShowTooltips= 1
ShowHints= 1
CurrentGpu= 0
Sync= 1
ShowOSDTime= 0
StartupDelay= 0
EnableLog= 0
RecreateLog= 0
LogPath=
LogLimit= 10
Link= 1
VideoCaptureFolder=
CaptureOSD= 1
[ATIADLHAL]
[NVAPIHAL]
Change that to UnofficialOverclockingMode= 0
· Premium Member
* Set UnofficialOverclockingEULA field to the following text: I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
* Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
This.
· Premium Member
Originally Posted by Mit Namso
For me MSIAB goes to a massive 840/1325
Luckily TRIXX goes to 1200/1800
But I have to use MSIAB for the voltage control
A solution is in this thread. I'll quote it again for you.
· Premium Member
Thanks, I was looking for a way to get above 950/1450 as well!
1 - 14 of 14 Posts
