Solved myself :p
324 Views 0 Replies 1 Participant Last post by  tK FuRY
So I'll admit I need some help now;
My decent board, I might call it crappy from now on, doesn't want to get back to 500MHz FSB :/
495 is perfectly stable, but 500 is a no no
I've went from 1.35v FSB to 1.4 now, and *OMG BOOTED* ... Yes I am typing this as I am tinkering with settings lol. (Apparently SpeedStep somehow reactivated.)
Will edit once I reboot into BIO - I find it funny that 2000QDR - 500FSB gives me the same performance as 475FSB 19xxQDR
L2 Cache speeds have went up, but that's it *****.
Multi - 8.5x for 4250, or 9x for 4500
PCI-E 1 & 2 - 100 MHz (Should I increase to 105-107?)
PCI-E 3 - 100 MHz (Should I increase ?)
Spread Spectrum (should these be disabled or enabled?
HT Spread - Disabled
PCIe Spread - Disabled
SATA Spread - Disabled
2000QDR - 500FSB
RAM: 1000MHz - 5-5-5-15
Limit CPUID - Disabled
Speedstep - Disabled
CPU Thermal - Disabled
C1E - Disabled
Execute Disable Bit - Enabled
Virtualization - Enabled
Voltages
Without Vdroop
1.3625 (trying to 4.5GHz)
CPU FSB - 1.400 (red according to this bios)
Memory - 2.025V
nForce SPP - 1.5V (red according to board)
nForce MCP - 1.550v
HT nForce SPP <-> MCP - 1.4
CPU PLL - 1.6
GTLVREF
1 - +55
2 - +60
3 - +55
4 - 0
Progress so far; http://valid.canardpc.com/show_oc.php?id=859755
http://valid.canardpc.com/show_oc.php?id=859793
Found my new point of diminishing returns lol;
4.4GHz - 1.368vcore on full load, new point
it used to be 4.175 @ 1.3 then 4.275 @ 1.33
1 - 1 of 1 Posts
1 - 1 of 1 Posts
