He already stated its now showing up in disk managementcheck Disk Management if you are using windows..you might need to initiate the new drive and format it..
no need to install any additional drivers, after choosing between GPT and MBR you should be able to format and be able to see it (assuming Windows did assign a drive letter for that partition)ok I think windows just had to reboot, because now when I opened DM, it asked right away which format for this drive, and it's "GPT 100%, MBR is for older versions of windows and legacy partitions"
Ok I did that, but I still don't see it listed in DM or winEX ????
Initialising the drive just lets Windows know that it can be used. You need to create a partition on it and format it as NTFS for it to actually show up as a usable drive. Once initialised, right click the region that says "Unallocated" and select "New Simple Volume" then follow the instructions.ok I think windows just had to reboot, because now when I opened DM, it asked right away which format for this drive, and it's "GPT 100%, MBR is for older versions of windows and legacy partitions"
