Well since i'm visiting this forum; I learned that OCing isn't just highering the FSB but also allot of other things, but there are still allot of things I don't get:
1. how do you know the max fsb supported for your ide/ata hardware?
2. when do you know when you have to higher your mb voltages?
3. how can you cool you mb if you complete question nr 2
4. how do you know when you have to raise your memory voltages?
5. how do you know your memory temps?
6. how do you know when you have to raise core voltages or memory voltages?
7. how do you know what the max cpu clock is that your mb supports?
The list will be continued
