Some questions for my mod
390 Views 7 Replies 3 Participants Last post by  NoodleGTS
Working on a new mod called Imolation (yes that's the correct spelling, see the mod first). I have a couple of general mod questions that hopefully you guys can answer.
answeredWhere can one get a quality UV light? I am trying to avoid Logysis as much as possible since their products are usually cheap and tacky. Also, the on/off PCI bracket is quite unprofessional.. Do they come with nicer looking switches (a la murderbox) or do I have to do my own modding?
answeredHow hard is it to cut a professional looking case window and what tools would it take? The reason I ask is because i have the option of getting the TJ07 without the window for over $100 less than with the window, but you can't simply buy a new side panel because of the way it's constructed. I'm aiming for something like this:
http://www.imagehost.co.za/uploads/2dsa5hwsxkef63dx.jpg
1) What's the best way to mount a rad in the bottom of a TJ07? I want the best possible rigidness because I don't want the radiator to come loose while I'm moving the case or something.
2) I'm going to have 6 fans down in the rad section.. what's the quickest and easiest way to power them? I just want them all at full power so no need for a fan controller. I don't want to piggy back them or anything that would make them perform worse.
3) What's a good sleeving kit? I want to sleeve all my case fan cables and some other unsightly cables around the case, but not the PSU
4) What's a good sound dampening material? They range in price from $10 to $50 and I need to make an educated decision choosing what will give best bang for the buck.
That's it for now, but may have questions later. Thanks!
1 - 8 of 8 Posts
Immolation, burning oneself to death...I love that name for a computer case! The lights if you can get them to flicker would be perfect. Just my two cents worth, the logisys lights are cheap but mine have been working great. I am going to rewire the switch onto a toggle for the front of my next "steampunked" case build.
The name comes from the color I'm going to be painting it, Imola orange. But yes, it is a pun! You know a Logysis meteor light could do the flickering trick, but that's not quite what I'm going for!
Bump bump...
Is there anything that does what this (http://www.performance-pcs.com/catal...oducts_id=4420) does without costing $19.95?? I just don't see why that needs to cost so much. Bad value FTL.
Also, can someone link to some good sound dampening sticky stuff? There's packs that range from $9.99 to $49.99 and I need to know what the best value along that scale is.
Thanks!
bump... help please!
Here you go, look under "Car Audio Noise Control" there are sprays, liners, etc.
http://www.parts-express.com/acoustic-noise-control.cfm
Thanks but I'm looking for a little more guidance as to which is the best value etc. I've gotten some from Xoxide.com in the past ~$15 and it was decent.
Also, any answers to the other Qs?
1 - 8 of 8 Posts
