1 - 4 of 4 Posts
I am going to build my first liquid cooling system and ask you some tips on two possible solutions, the first contemplate the use of a bayres 5.25 ", while the second employs a cylindrical tank and a top for uncoupling the pump, rather the first configuration only for aesthetic, I would like to know if this solution will cause the performance and bleeding air ?
If you have other suggestions on how to improve my cycle I would be happy
Thanks
Sorry for my bad english
Regards
Hi Guy! Thanks for your support
I finished more examples of cycles, if you know the solution combo there are vibrations?
I would like a silent system
1 - 4 of 4 Posts
