1 - 5 of 5 Posts
Too Poor For This
Just wanted to know if there is a mystery folder out there giving me a boost? I have an i5 650 @4.514 and a watercooled GTX 470 which gives me a respectable 21k PPD according to HFM and past folding but my last three updates have been 8k, 6k and then 10k. I'm assuming they're helping me reach 1 million points since I'm only 75k off.
They're getting at least 4k per update which will end up around 32-36k PPD. That could easily be a pair of watercooled 470s or a 480 with an i7 (no -bigadv) which seams about right to me.
If you are doing this on purpose and not by accident I thank you very much and would like to know the identity but if not it's ok and thanks again
I wonder if you finished a bunch of Gen 44 GPU units unknowingly (5 min WUs that give normal points)
Reactions: VW_TDI_02
Too Poor For This
Discussion Starter #4
I'm pretty sure you're right. I just looked at my log and i found a few that were completed without showing any %.
[12:31:56] + Attempting to send results [September 13 12:31:56 UTC]
[12:31:56] Gpu type=3 species=30.
[12:32:03] + Results successfully sent
[12:32:03] Thank you for your contribution to [email protected]
[12:32:03] + Number of Units Completed: 584
[12:32:07] - Preparing to get new work unit...
[12:32:07] Cleaning up work directory
[12:32:07] + Attempting to get work packet
[12:32:07] Passkey found
[12:32:07] Gpu type=3 species=30.
[12:32:07] - Connecting to assignment server
[12:32:08] - Successful: assigned to (171.67.108.32).
[12:32:08] + News From [email protected]: Welcome to [email protected]
[12:32:08] Loaded queue successfully.
[12:32:08] Gpu type=3 species=30.
[12:32:09] + Closed connections
[12:32:09]
[12:32:09] + Processing work unit
[12:32:09] Core required: FahCore_15.exe
[12:32:09] Core found.
[12:32:09] Working on queue slot 01 [September 13 12:32:09 UTC]
[12:32:09] + Working ...
[12:32:09]
[12:32:09] *------------------------------*
[12:32:09] [email protected] GPU Core -- Beta
[12:32:09] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[12:32:09]
[12:32:09] Build host: SimbiosNvdWin7
[12:32:09] Board Type: Nvidia
[12:32:09] Core      :
[12:32:09] Preparing to commence simulation
[12:32:09] - Looking at optimizations...
[12:32:09] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[12:32:09] - Created dyn
[12:32:09] - Files status OK
[12:32:09] sizeof(CORE_PACKET_HDR) = 512 file=<>
[12:32:09] - Expanded 18945 -> 76495 (decompressed 403.7 percent)
[12:32:09] Called DecompressByteArray: compressed_data_size=18945 data_size=76495, decompressed_data_size=76495 diff=0
[12:32:09] - Digital signature verified
[12:32:09]
[12:32:09] Project: 11240 (Run 0, Clone 0, Gen 44)
[12:32:09]
[12:32:09] Assembly optimizations on if available.
[12:32:09] Entering M.D.
[12:32:15] Tpr hash work/wudata_01.tpr:  2237887125 1170854844 4148543684 3285333439 1788879763
[12:32:15] Working on 264 Fs_coil
[12:32:15] Client config found, loading data.
[12:32:15] Starting GUI Server
[12:36:18] Finished fah_main
[12:36:18]
[12:36:18] Successful run
[12:36:18] DynamicWrapper: Finished Work Unit: sleep=10000
[12:36:28] Reserved 54092 bytes for xtc file; Cosm status=0
[12:36:28] Allocated 54092 bytes for xtc file
[12:36:28] - Reading up to 54092 from "work/wudata_01.xtc": Read 54092
[12:36:28] Read 54092 bytes from xtc file; available packet space=786376372
[12:36:28] xtc file hash check passed.
[12:36:28] Reserved 0 0 786376372 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[12:36:28] Allocated 544 bytes for edr file
[12:36:28] Read bedfile
[12:36:28] edr file hash check passed.
[12:36:28] Allocated 22433 bytes for logfile
[12:36:28] Read logfile
[12:36:28] GuardedRun: success in DynamicWrapper
[12:36:28] GuardedRun: done
[12:36:28] Run: GuardedRun completed.
[12:36:29] + Opened results file
[12:36:29] - Writing 77581 bytes of core data to disk...
[12:36:29] Done: 77069 -> 58878 (compressed to 76.3 percent)
[12:36:29]   ... Done.
[12:36:29] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[12:36:29] Shutting down core
[12:36:29]
[12:36:29] [email protected] Core Shutdown: FINISHED_UNIT
[12:36:33] CoreStatus = 64 (100)
[12:36:33] Sending work to server
[12:36:33] Project: 11240 (Run 0, Clone 0, Gen 44)
[12:36:33] - Read packet limit of 540015616... Set to 524286976.
[12:36:33] + Attempting to send results [September 13 12:36:33 UTC]
[12:36:33] Gpu type=3 species=30.
[12:36:34] + Results successfully sent
[12:36:34] Thank you for your contribution to [email protected]
[12:36:34] + Number of Units Completed: 585
[12:36:38] - Preparing to get new work unit...
[12:36:38] Cleaning up work directory
[12:36:38] + Attempting to get work packet
[12:36:38] Passkey found
[12:36:38] Gpu type=3 species=30.
[12:36:38] - Connecting to assignment server
[12:36:38] - Successful: assigned to (171.67.108.32).
[12:36:38] + News From [email protected]: Welcome to [email protected]
[12:36:38] Loaded queue successfully.
[12:36:39] + Closed connections
[12:36:39]
[12:36:39] + Processing work unit
[12:36:39] Core required: FahCore_15.exe
[12:36:39] Core found.
[12:36:39] Working on queue slot 02 [September 13 12:36:39 UTC]
[12:36:39] + Working ...
[12:36:39]
[12:36:39] *------------------------------*
[12:36:39] [email protected] GPU Core -- Beta
[12:36:39] Version 2.09 (Thu May 20 11:58:42 PDT 2010)
[12:36:39]
[12:36:39] Build host: SimbiosNvdWin7
[12:36:39] Board Type: Nvidia
[12:36:39] Core      :
[12:36:39] Preparing to commence simulation
[12:36:39] - Looking at optimizations...
[12:36:39] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[12:36:39] - Created dyn
[12:36:39] - Files status OK
[12:36:39] sizeof(CORE_PACKET_HDR) = 512 file=<>
[12:36:39] - Expanded 20573 -> 77539 (decompressed 376.8 percent)
[12:36:39] Called DecompressByteArray: compressed_data_size=20573 data_size=77539, decompressed_data_size=77539 diff=0
[12:36:39] - Digital signature verified
[12:36:39]
[12:36:39] Project: 10940 (Run 0, Clone 1, Gen 44)
[12:36:39]
[12:36:39] Assembly optimizations on if available.
[12:36:39] Entering M.D.
[12:36:45] Tpr hash work/wudata_02.tpr:  1264656079 4268936276 799544256 2652134781 3291702893
[12:36:45] Working on 247 ProG_hpin
[12:36:45] Client config found, loading data.
[12:36:45] Starting GUI Server
[12:40:50] Finished fah_main
[12:40:50]
[12:40:50] Successful run
[12:40:50] DynamicWrapper: Finished Work Unit: sleep=10000
[12:41:00] Reserved 50768 bytes for xtc file; Cosm status=0
[12:41:00] Allocated 50768 bytes for xtc file
[12:41:00] - Reading up to 50768 from "work/wudata_02.xtc": Read 50768
[12:41:00] Read 50768 bytes from xtc file; available packet space=786379696
[12:41:00] xtc file hash check passed.
[12:41:00] Reserved 0 0 786379696 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[12:41:00] Allocated 544 bytes for edr file
[12:41:00] Read bedfile
[12:41:00] edr file hash check passed.
[12:41:00] Allocated 22433 bytes for logfile
[12:41:00] Read logfile
[12:41:00] GuardedRun: success in DynamicWrapper
[12:41:00] GuardedRun: done
[12:41:00] Run: GuardedRun completed.
[12:41:04] + Opened results file
[12:41:04] - Writing 74257 bytes of core data to disk...
[12:41:04] Done: 73745 -> 55414 (compressed to 75.1 percent)
[12:41:04]   ... Done.
[12:41:04] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[12:41:04] Shutting down core
[12:41:04]
[12:41:04] [email protected] Core Shutdown: FINISHED_UNIT
[12:41:07] CoreStatus = 64 (100)
[12:41:07] Sending work to server
[12:41:07] Project: 10940 (Run 0, Clone 1, Gen 44)
[12:41:07] - Read packet limit of 540015616... Set to 524286976.
[12:41:07] + Attempting to send results [September 13 12:41:07 UTC]
[12:41:07] Gpu type=3 species=30.
[12:41:08] + Results successfully sent
[12:41:08] Thank you for your contribution to [email protected]
[12:41:08] + Number of Units Completed: 586
[12:41:12] - Preparing to get new work unit...
[12:41:12] Cleaning up work directory
[12:41:12] + Attempting to get work packet
[12:41:12] Passkey found
[12:41:12] Gpu type=3 species=30.
[12:41:12] - Connecting to assignment server
[12:41:12] - Successful: assigned to (171.67.108.32).
[12:41:12] + News From [email protected]: Welcome to [email protected]
[12:41:13] Loaded queue successfully.
[12:41:13] Gpu type=3 species=30.
[12:41:13] + Closed connections
That explains my thoughts too... I just noticed the exact same thing with an increase of PPD more than what I at first thought was capable.
Good to know we are both cranking our higher PPD out under our own steam hey
1 - 5 of 5 Posts
