Why? What do you want to know?
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!MiPfPutPagesInTransition+6d5
81cc18d7 895cbe1c mov dword ptr [esi+edi*4+1Ch],ebx
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiPfPutPagesInTransition+6d5
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 48d1b7fa
IMAGE_NAME: [B]memory_corruption[/B]
FAILURE_BUCKET_ID: 0xA_nt!MiPfPutPagesInTransition+6d5
Followup: MachineOwner
1: kd> !analyze -v
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: c71ffc30, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 81cc18d7, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 81d6b868
Unable to read MiSystemVaType memory at 81d4b420
c71ffc30
CURRENT_IRQL: 2
FAULTING_IP:
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: svchost.exe
Originally Posted by h00chi3 ![]() Go into device manager and make sure the ATI device driver is also uninstalled. |
Originally Posted by Maddog7771 ![]() i had the same error before and was caused my memory also memtest can be found on most linux disk. http://www.memtest.org/ |
