1 - 6 of 6 Posts
hey im kinda noobie to this whole scene of over clocking , i would like some help on how to over clock my cpu to about 3 ghz if possible, i dont know how 2 do it and what programs 2 use so im kinda noobie, any1 have msn and explain to me step by step? help would be appreciated, thanks
ur goin to want some better cooling than stock
basically all you need to do is raise the fsb up say 5mhz at a time, then when it doesnt post ( power on self test ) or it post's and doesnt get into windows then come back and we can adivse you from there <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
most of the new c2d's go quite high on stock voltage.
To hit as high as 3GHz you'll probably need better than stock, speaking from personal experience. I'm hitting 2.6GHz , w/ load temps of 55
<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> Greetings,<br><br>
You will need to do the Following:<br><ul><li>Read and educate yourself: OC'ing isn't cookie-cutting. someone else's numbers may not work.</li>
<li>Know your hardware's limits on voltage and temps.</li>
<li>Get aftermarket cooling</li>
<li>Have patience and be prepared to do a lot testing and re-starting.</li>
<li>Be prepared for crashes.</li>
<li>Familiarize yourself with 3DMark06, Prime95, CPUz (as examples)</li>
</ul><br>
Start there. As your questions arise, ask them. If I may be so bold, may I ask the first one for you? Okay I'll take a chance.<br><br>
What air-cooling should I use? Try The Tuniq 120, Scythe Ninjo, Noctua 120, or any other similar tower-cooler that has a large dissipation surface area.<br><br>
Why that one? Protecting your hardware is paramount. As I said you will get crashes, but if the numbers are within tolerable specs there will be no damage to the hardware.<br><br>
If you are on a tight budget and can only use what you have, you could find a desk fan and OC while your case is open and the fan is blowing onto the HSF on your CPU.<br><br>
Hope that this helps, and good luck. Have fun with it! <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 6 of 6 Posts
