Well this happend to me an my CS. However all was fixed with a driver update. I reccomend you update your video Drivers...it may be a conflict or compatibility issue but to be sure when doing so use this provedure :
.Installing Graphic card driver efficiently!!! When you Update your graphics cards drivers theres ways that you should go about it. Follow these simple steps below.
1.Download and install ''Driver Cleaner'' Here:
http://www.drivercleaner.net/professional.html
2.Uninstall your Current Display drivers such as your ''ATI'' or ''Nvidia'' drivers.
3.Now run ''Driver cleaner'' and depending on the Drivers you have you will have to select either ''ATI'' or ''Nvidia'' from the drop down menu. Only select the main title of the driver in the drop down such as just ''ATI'' or ''Nvidia''
4.Once you have selected Your driver click on the ''Start'' button and this will now start the driver cleaning process. ( Do this twice to be sure )
5.Now reboot your system and Download the latest Nvidia or ATI and go ahead and install them.
Doing this avoids driver corruption and conflicts so you can now enjoy smooth gameplay.
