1 - 3 of 3 Posts
Hi, I am having troubles accesing my memory card for my digital camera. When I put it in the sandisk memory port, it says auto play with the flashlight that is searching. Then...nothing. I go into "my computer and when i click on it, it says,
"G:\\ is not accesable
the request could not be performed because of an I/O device error"
make sure the drivers are installed updated? and check to see that the mem. stick is in all the way.... i dunno thats my geuss lol
I had the same problem. It wasn't accessiable at all. Google for memory stick data recovery etc. Run the program to get as much data as possiable, then you'll need to RMA it. The stick should have damaged by too much data being writen on it at the same time.
1 - 3 of 3 Posts
