1 - 14 of 14 Posts
So, I just finished putting together all the parts in my sig. I plug the power cord into my power supply, plug the other end into the wall and...
nothing.
I'm flummoxed. Is there something really simple and obvious that I'm overlooking or should I start unplugging the connectors in preparation for the inevitable buy.com rma process?
Problem solved. I'm ******ed. Thanks to those of you who took the time to help me with my nonexistent problem.
Originally Posted by crashnburn_819
Could be a lot of things.
Power switch is off
Ram is dead
CPU is dead
Cable somewhere is bad or not plugged in all the way
The power supply isn't turning on at all. How is that a function of the ram or cpu? Actually, I didn't mention that so I guess that's a fair assessment of what could be wrong. Am I wrong in thinking that at least the power supply fan would come on even if the cpu or ram were dead?
Originally Posted by McStuff
Make sure the switch on the back of the psu is on. And make sure the power button is plugged in correctly.
The switch on the back of the psu is on and I've just made sure that the cord on both ends is secured. Still nothing.
if the motherboard has a built in on/off switch, unplug your case leads and try using that to power the system on
Do the mobo lights come on when the power is plugged in but the system is not on? What exactly does it do.
Discussion Starter · #8 ·
Hahahahahahaha. God, I'm ******ed. I plugged my comp into a socket in my new apartment that requires a light switch to be turned on for the power.
Flipped the switch and everything's gravy.
Thanks guys for briefly indulging my idiocy
Nice!
Discussion Starter · #14 ·
Originally Posted by smoke12291
lol
I hate it when I do stuff like that...which is a lot...
glad to hear it's working.
Yea, I try to limit the amount of times a day that I'm ridiculously oblivious to the simplest of things, but nevertheless, I still have a fair amount of boneheaded blunders attributed to my name
. Thanks for the sympathy and the well wishes.
Originally Posted by Murderous Moppet
Wow, great you got that working.
When I read the thread title I thought you were posting about the plot of Crysis.
You know, I haven't played crysis yet, but I did get it for $10 yesterday at best buy. I'll finally get a chance to truly understand all the Crysis jokes that I read on forums all day.
1 - 14 of 14 Posts
