Sorry, another new build post
337 3
Hi all,
Im sure this is a very common topic, but seems that each individual is different. I know theres no the RIGHT ONE answer to this question, but i would appreciate your comments.
Im building a new setup, and for some reason the 2nd setup is harder than the first one i did 3 years ago. Maybe because my current setup still running ok.
These are the parts that im considering.
- Thermaltake SHARK VA7000SWA Silver 1.0 mm All aluminum ATX Full Tower
- Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 Hard Drive
- ViewSonic VX922 Black/Silver 19" 2ms LCD Monitor - Retail
- ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
- ATI 100-435805 Radeon X1900XTX 512MB GDDR3 PCI Express x16 Video
- Creative Sound Blaster X-Fi XtremeMusic 7.1 Channels PCI Interface Sound
- Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply - Retail
- ZALMAN CNPS9500 LED 92mm 2 BallBlue LED Light Cooling Fan heatsink
- CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC3200)
- AMD Athlon 64 X2 4200+ Manchester 1GHz FSB Socket 939 Dual Core
My questions are more related to MB and VID card. Thinking in investment protection, should i go with Crossfire MB and x1900xt instead of XTX? and who knows, in the future may add the crossfire version of the X1900xt.
From Mobo perpective, use nvidia chipset, or KT, if crossfire is ok, what mb vendor is recommended?. All opinions are welcome,
regards,
1 - 4 of 4 Posts
Originally Posted by fath3r
Hi all,
regards,
Hi Fath3r,
Wow that will be some set up! Anyway to your question. I'd go with the nVidia chipset over the KT. The reviews all over the net will support this. As for a motherboard, either the ASUS or DFI. MSI or Gigabyte would be other good choices. DFI seem to have become the favorite over the past couple of years with their Lan party series. The boards also come with lots of extras. As for the video card. Can't go wrong with the X1900XTX, but I don't know how plentiful they are right now. You could go a step down to a GeForce 7800 Ultra or X1800XtX and put the "saved" monies into a 150GB Raptor drive. They are out now and are real fast with good space...
Just my humble opinion of course, :)
thanks 455 for your comments.
I will check DFI.
Anyone know the difference between x1900xtx and x1900xt beside clock speed and crossfire support?
Also, the stup i post, anyone know if could be overclockable?
regards,
I will check DFI.
regards,
If you want an X1900XTX you should get the newest RD480 board from Saphire.
http://www.newegg.com/Product/Produc...82E16813154007
It is the newest and supposidly best ATI Crossfire motherboard availible.
The difference between the X1900XT and X1900XTX are that the XTX uses better ram, 1.1 ns vs. the XT's 1.2ns ram, (it is possible that some OEM XT's may have 1.1ns ram). The X1900XTX is a slightly better card, it is more then just clock speeds.
1 - 4 of 4 Posts
