1 - 5 of 5 Posts
Ok, this is what I'm looking at getting.<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16829102004" target="_blank">Creative Sound Blaster Audigy 4 $41.99 after mail in rebate</a><br />
<br />
<a href="http://justdeals.com/Items/980374-0403?" target="_blank">Logitech USB Stereo Headset 350 $16.95</a><br />
<br />
<a href="http://www.justdeals.com/Items/970114-0403?" target="_blank">Logitech X-530 5.1 Surround Sound Speakers & Subwoofer $39.95</a><br />
<br />
What is the difference between the <a href="http://justdeals.com/Items/GS_980356-0403?" target="_blank">250</a> and <a href="http://justdeals.com/Items/980374-0403?" target="_blank">350</a> version of the Logitech USB headset? I'm guessing it's just the quality?<br />
<br />
I want to get a usb headset so I don't have to plug the headset into the sound card which is at the back of my computer. If I get a usb headset then I can easily plug it in, and unplug it.<br />
<br />
If you have any suggestions, please post them.<br />
<br />
Thanks
Alright...I was kinda thinking that would be the case. I'll have to re-think what headset I'll get.
Discussion Starter #4
Before I buy, I just want to make sure everything will work together. The Logitech X-530 speakers will work with the Audigy 4 sound card, right?<br />
<br />
Thanks
yeah, they'll work... I wouldn't spend money on an audigy 4 though... it's old technology. get an x-fi. you can get cheaper x-fi's now so take a look at those before you buy
1 - 5 of 5 Posts
