1 - 7 of 7 Posts
Well i have been debating on which way to go .Currently im using onboard sound from my 750i xfx board.But i listen to a lot of music and watch movies as well as game.
So this bring's me to my question what would be a better investment a Sound card or some new Speaker's.I am using a Phillips 38watt smart sound solution which has two vocal speakers and a small subb.I use to use a Regent home surrond sytem with 5 speakers and Big sub and driver which sounded Great and Really Cranked.
Im looking mainly to making things louder and Sound better.So what should i do ?
These if you can afford them, http://www.newegg.com/Product/Produc...e&Order=PRICED
Or these if you need cheaper http://www.newegg.com/Product/Produc...82E16836121006 ( work great, my buddy cranks them and they sound clear, surprising bass as well )
You will see more gain in speakers as the integrated sound chips these days are good enough for output. Getting a sound card and not new speakers will probably give you a better ( cleaner amplified sound) but not by much and definitely not as noticeable as a new set of speakers.
i was looking on new egg and was looking specifically at this 2 that was in my price range
logitech X-540 70 watt 5.1 speakers
Logitech Z-2300 200 watts RMS 2.1 Speaker System
i just dont know which would be more of a Gain than the phillips 38w 2 channel i have now.It has been awhile since i have fooled with anything audio related but i would assume the 200watt 2.1 would be louder and still provide Good sound
Logitech speakers aren't very good at any price range. Especially the Z5500's. Just...stay away from them before you get buyers remorse.
If you're looking to spend around $100 get the before mentioned Klipsch Promedia 2.1 set.
1 - 7 of 7 Posts
