Originally Posted by Sper oh and BTW i did NOT fix the PCI/AGP freq...Jisses.....what do i set it on 66 mhz? Radeon 9800 pro is clocked also =D] |
Originally Posted by archer_456 yes lock the PCI on 33Mhz and AGP on 66Mhz. more than likely thats your problem. |
Originally Posted by Sper hm weird i cant find so i can lock pci on 33mhz only the AGP on 66 Only thing that uses PCI slots is network card though...hm |
Originally Posted by archer_456 The PCI slots are not the only running off the PCI bus. your sound and several other things also run off the same PCI bus. do you see any option in your BIOS that will let you change your Chipset from running synchronous to asynchronous with the FSB or CPU external frequency? |
Originally Posted by Sper Only thing i can fins is Pci Latency Timer and Onchip 1394 |
Originally Posted by ShawnMcGrail Okay, well If its the Southbridge causing is causeing the sound to go out, could that be my problem also? I have a PCI/AGP lock, and after about 10-15minutes of gameplay, I lose my sound, ? no? lol |
Originally Posted by ShawnMcGrail Its hard to tell if its stable or not with this processor, I know that with AMD's and prescotts you can tell your pushing the limits by the temps. But with this CPU, it idles @ 17 and load @35-38C. Should I just throw a hsf on the southbridge? |
