1 - 2 of 2 Posts
My front audio cable can barely reach the sound module. After reseating my heatsink today, I decided it wasn't worth it to plug it in, because I never use front audio. Now my sound doesn't work. To plug the front audio back in I'll have to take out my exhaust fan and it'll probably take me a while to manage to get the plugs onto the right pins(the block connector doesn't reach).
Shouldn't it still work, even if I don't have the front audio plugged in?
Did you have the cable plugged it before this happened? If you did, you probally remember having to take the jumpers off the connectors on the mobo so you could plug in the front audio jacks. And because now you don't have the wire hooked up you need to re-jump the pins again. If you take a look in your owners manual for your mobo they will say which pins you have to jump.
1 - 2 of 2 Posts
