1 - 2 of 2 Posts
I broke the ring tip of my laptop and now when i try to plug in the speaker it wont work , is there a ring i can buy../?
do you have a picture? did you break the mini plug from your speakers off in your laptop? I guess I'm not sure what you're trying to say. If you just broke the plug that's an easy fix. The jack, may be more difficult
1 - 2 of 2 Posts
