1 - 15 of 15 Posts
With the massive overhauls they've been doing to allow the mac version, is there a way I can use OpenGL instead of DirectX in wine to play CS:S/TF2?
Discussion Starter #4
Originally Posted by eseb1 View Post
Well they said DX 10/11 now runs natively on Linux using the same methods Wine uses.
No. Wine translates DirectX into OpenGL.
You've always been able to use OGL for wine...
http://wiki.winehq.org/UsefulRegistryKeys
      |  +->DirectDrawRenderer
      |  |   [Select what backend to use for DDraw. Valid options are:
      |  |    gdi - Use GDI to draw on the screen (slow but reliable) (default)
      |  |    opengl - Use OpenGL (fast but not all programs work correctly)
      |  |    see http://wiki.winehq.org/DirectDraw for more information]
Linux doesn't use the game settings directly and so when you switch "in game" settings like DX/OGL your still not switching how Wine is drawing the game. That's done above and is the only real way to use OGL with Wine.
Reactions: Jimi
Thanks mushroomboy +rep
But remember different games run better or worse with this, different wine prefix's are suggested with these types of tweaks.
i've got a stupid question.
what would be harder, getting a windows program working in linux or getting a mac program working in linux (maybe bsd since it is closer to that.)
i know there is a large range of proprietary stuff for mac os x which is not pushed back to open source.
this is interesting none the less, i'm thinking of giving this a shot
getting OSX apps to run as outside of a VM I don't think it's very feasible
i know it has something to do with elf binary and non elf binary, and the fact that cocoa is their main api lib, and it hink the other is carbon, i know cocoa has a opensource variant, called gnustep i believe, but their is none for carbon.
sorry to hijack your thread jimi
Discussion Starter #13
No it's okay, because I basically made the topic thinking if it would be better to run the mac version (since its native opengl)
there are many other problems with this as well, such as audio libraries.... I actually don't think there is any real way to run OSX applications inside linux. it's a shame because you'd think it would be easier. I guess it comes down to as 'why'? Why make OSX apps run in Linux? The few audio solutions you have probably wouldn't work well anyways and I can't think of any other reason. =(
1 - 15 of 15 Posts
