1 - 1 of 1 Posts
I recently pulled a e6400 from my sig rig and replaced it with a q6600. I'm going to put the e6400 in the S3G in my sig. So I have the following components laying around:
E2180
20X DVDRW
80 gig IDE HD (though I may pull the 2 x 320 gig seagate 7200.10 from my sig rig, put the 640 gigs in raid 0 and use the 1TB as backup)
I have a 37" Vizio 720P HDTV that will be the main display.
I have a psu but seems it was pulled from my brothers computer and replaced so I don't think it works
I don't plan to game on this machine so onboard video is fine, so long as it can play video without stuttering. I want to build as cheap as possible. I figured the e2180 currently at 3.2 ghz is pulling 2K ppd in folding, so I should be able to get 1.5k ish at stock.
So unless you can send me some cheaper components (used is fine) then this is what I'm planning
Rosewill R102-P-BK 120mm Fan MicroATX Mid Tower Computer Case $29.99
LOGISYS Computer PS480D 480W ATX12V Power Supply $18.99
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model ADQVE1A16K $39.99
BIOSTAR G31D-M7 LGA 775 Intel G31 Micro ATX Intel Motherboard - Retail
1 - 1 of 1 Posts
