1 - 4 of 4 Posts
i measured the height of my cpu cooler and the cpu cooler space inside the nzxt lexa case
the case capacity for cpu cooler mounted + with the side fan attached to the side of the case is 5.55" - around 14.1 cm
the height of my spartan he924 cpu cooler is 13.5 cm
is the remaining space - when we subtract those two values - enough for the cpu cooler and side fan to work together without causing any problems?
thank you very much in advance
From what I can understand from your measurements it sounds like the CPU cooler you have chosen will fit inside the case with 0.6cm to spare.
At most the side panel fan will help cool the heatsink.
1 - 4 of 4 Posts
