1 - 20 of 25 Posts
I am trying to hook my digital out on my sound card to the coaxial digital in on my receiver for a HTPC. Where can I get a cable that adapts a stereo jack to 1 rca. There are tons that do a stereo jack to 2 rca's but a coaxial is only 1 rca.
I've been toying with the idea of making a couple of those cables... Just haven't decided if I want to go for it yet.<br />
<br />
blue jeans cable will make one for you. it'll cost $5 more then their standard RCA coax cable. just email them and they'll send you a link to their custom ordering page. <br />
<br />
I'm either going to build a couple or order from them in the next few days so maybe we could save on shipping... or if I opt to build myself I could just order an extra pair of plugs
Reactions: cdub998
I would make one, there pretty cheap
Reactions: cdub998
Discussion Starter #4
So they arent hard to make at all then. I have all the stuff at my house. Guess I have a weekend project. Thanks guys.
I use a mono mini to rca cable and it works great. It cost 10 bucks at radio shack. If you make your own be sure to get a mono mini plug not a stereo one or it will not work.
Yep, mono rca to mono 3.5mm with a 75ohm cable
Discussion Starter #7
I already have a mono rca cable just need the stereo jack i think. Thanks again.
wait up a min... You need 75 Ohm cable and a special 75 Ohm RCA plug. the mini won't be 75 Ohm, but the Canare F11 would work well for that<br />
<br />
so unless you have the right cable and/or know what you're doing it would be better to buy one<br />
<br />
BJC will make one for $20
Discussion Starter #9
I actually have a coaxial cable (rca) I was using for my old cable box. Al I need is to splice it into a Stereo jack that I can pull from a old set of computer speakers.
<tr>
<div>
Originally Posted by <strong>cdub998</strong>
</div>
<div style="font-style:italic">I actually have a coaxial cable (rca) I was using for my old cable box. Al I need is to splice it into a Stereo jack that I can pull from a old set of computer speakers.</div>
</td>
</tr>
</table>
</div><br />
<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> that doesn't make sense... why are you going to take a mono coax cable and put a stereo mini plug on it? <br />
<br />
You would need a mono mini plug at the other end if you want to use it as a digital coax cable. Also, you would need to buy a new plug and actually solder the connections because just splicing the connection will give you a really crappy signal... and it won't be 75 Ohms the entire length of the cable
Discussion Starter #11
Why not I am looking for a cable with a stereo jack on one side and a RCA jack on the other. If I have a RCA cable I was using for my coaxial audio on my receiver why not solder a stereo jack on the other side? What else would I do?
<tr>
<div>
</div>
<div style="font-style:italic">Why not I am looking for a cable with a stereo jack on one side and a RCA jack on the other. If I have a RCA cable I was using for my coaxial audio on my receiver why not solder a stereo jack on the other side? What else would I do?</div>
</td>
</tr>
</table>
</div>so you want an analogue stereo mini to 2 RCA plugs (left and right)?
Discussion Starter #13
<tr>
<div>
Originally Posted by <strong>soloz2</strong>
</div>
<div style="font-style:italic">so you want an analogue stereo mini to 2 RCA plugs (left and right)?</div>
</td>
</tr>
</table>
</div>coaxial digial on my receiver is only one plug. Its just an RCA interface but is a digital connection (like optical but the wire is analog) so no need for 2 plugs. The receiver does the processing.
<tr>
<div>
</div>
<div style="font-style:italic">coaxial digial on my receiver is only one plug. Its just an RCA interface but is a digital connection (like optical but the wire is analog) so no need for 2 plugs. The receiver does the processing.</div>
</td>
</tr>
</table>
</div>yes, but not quite....just because it isn't an optical connection doesn't mean it's not the same, the cable sends 1's and 0's.. it is a digital cable. (yes, transfer is in much the same way as an analogue cable)<br />
<br />
<tr>
</td>
</tr>
</table>
</div>And you do not want a stereo plug... you want a mono one. I suggest you buy a cable instead of attempting to make one, or at least do some more research before attempting to make one.
<tr>
</td>
</tr>
</table>
</div>owned <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Discussion Starter #16
Well you guys all said it was easy. no one told me any different until now.
It is easy, if you know what you're doing. I've made several cables before<br />
<br />
pics of a couple of them <br />
<img src="http://img139.imageshack.us/img139/9092/img239411qa5.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /><br />
<br />
but I'm not sure I want to try this... If the 75 Ohm RCA connectors had solder lugs I'd dive right in bc I can solder... but they crimp so that's what is holding me back. <br />
<br />
But here are the parts I'm looking at and they would all work together<br />
<br />
cable:<br />
<a href="http://www.markertek.com/Product.asp?baseItem=BL%2D1694A&cat=CABLESCONN&subcat=BULKCABLE&prodClass=DVIDEOBULK&mfg=&search=0&off=" target="_blank">http://www.markertek.com/Product.asp...&search=0&off=</a><br />
RCA 75Ohm:<br />
<a href="http://www.markertek.com/SearchProduct.asp?off=0&sort=prod" target="_blank">http://www.markertek.com/SearchProdu...ff=0&sort=prod</a><br />
Mono mini plug:<br />
<a href="http://www.markertek.com/SearchProduct.asp?item=F%2D11&off=0&sort=prod" target="_blank">http://www.markertek.com/SearchProdu...ff=0&sort=prod</a><br />
<br />
a cable would cost about $10-12 plus shipping depending on how long you wanted it. Then you'd have to make it... and Blue Jeans Cable will make one for $20 plus shipping... so they are very reasonably priced. The thing is that I'd really like 2 mini-RCA digital coax cables and one normal rca-rca digital coax... and that adds up and would be cheaper for me to build them.
found some more info... the actual parts to build the cable are cheap, but the tools are pretty spendy <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><br><a href="http://www.bus.ucf.edu/cwhite/theater/DIYCable.htm" target="_blank">http://www.bus.ucf.edu/cwhite/theater/DIYCable.htm</a><br><br>
I've heard of people soldering the pin and then crimping the sleeve... but I'm just not sure I think I'd rather just buy one at this point. Since I've already been in contact w/ BJC I emailed them to ask about a multiple cable discount
I have done this a million times. I just take some dual shielded coax and get two rca ends. Get a wire stripper, and a crimper. If its a long run I will use a quad shield cable, then just get an adapter to fit the sound card.<br />
<br />
pink
Discussion Starter #20
<div>Originally Posted by <strong>Mr Pink57</strong></div>
<div style="font-style:italic;">I have done this a million times. I just take some dual shielded coax and get two rca ends. Get a wire stripper, and a crimper. If its a long run I will use a quad shield cable, then just get an adapter to fit the sound card.<br><br>
pink</div>
</td>
</tr></table></div>
So they make an adapter for the sound card? Where? I have a freakin 75 ohm rca I just need the adapter.
1 - 20 of 25 Posts
