1 - 4 of 4 Posts
So I'm trying to troubleshoot where the source of my speaker static is coming from.
Here is my setup -
PSU - Coolermaster V700
GPU - Powercolor 7950
Motherboard - MSI z97m Gaming
CPU - 4790k
Case - Fractal Node 804
Speakers - M-Audio BX5 Carbon
So at first, I thought it was the speakers having a crappy internal AMP.
- However, when the audio cable is unplugged from my computer, there is no more static.
So maybe the motherboard sound card is the problem?
- I used an external usb sound card (sound blaster SB0300), however I kept getting the same static. When I unplugged the usb from the computer, the static stopped. So even the usb ports are causing interference. So it can't be some sort of power issue/grounding issue (sound card powered via AC adapter).
So I'm down to two things, the power supply or the motherboard?
- When Furmark is run, static can be heard, when prime95 is run, static can be heard. When my computer is at idle, there is little interference.
Originally Posted by Tiihokatti View Post
Groundloop.
Your PC is grounded and so is your M-Audio, and that creates a groundloop as both of them are connected to the same ground.
Get a groundloop isolator to fix it.
Would something like this be okay? I was reading the reviews and was worried that some frequencies are cut off.
I plugged my speakers into the same circuit, HOWEVER, I plugged the speakers into my Home Theater Power Console/Power Conditioner and the noise was drastically lowered. Although at High Volumes I can still hear the static, but I never listen to it that high. When I plug the speakers into the computer though, I can hear the static as usual. The USB sound card here lowers that sound. So if I were to get that groundloop isolator, I should in theory be able to just plug in the speakers directly into my computer?
It may be groundloop as stated already. Make sure that all connections are secure. I am assuming they are connected 1/4in to 1/8(3.5mm)? Also some other options to try to troubleshoot are to disable the front audio ports and any unused line-in/line-out in control panel. Another thing to try if possible is connecting the computer and the speakers to separate outlets
I had the same problem with my BX5's but it was because they were hooked up via XLR and I kept the 1/4 cables connected as well since occasionally I would hook up my ipod to them and it was creating the static noise. I almost went insane trying to figure out what the problem was. I rma'd the video card, power supply, etc.
1 - 4 of 4 Posts
