1 - 5 of 5 Posts
Hello, how are you?
I finished my new build and setup.
Built an itx pc on a Ml08 and got a 55 inch 4k tv.
So far I am loving it and gaming at native 4k at 60fps on a 55 inch screen is really something.
But now I am debating with sound.
At the moment I just have the pc connected by HDMI to the TV and I am using the TV speakers.
The TV is a Sony Xe90. While it doesn't have terrible sound, it is not good either, so I am looking at improving it.
I don't want to break the bank and I don't want to get a complicated system with a receiver and lots of speakers.
So I am looking at either getting a 2.1 or 3.1 soundbar or getting a pair of studio monitors to have a 2.0 setup with each speaker on the side of the TV.
The final option is to get a 2.1 pc system like the logitech z625.
But I don't know what would be better.
The usage would be 70% gaming and 30% movies and Netflix shows.
I am a complete newbie in audio setups, so I am looking for some help.
Thank you.
Cheers
Discussion Starter #4
budget? Country?
I personally like separates a small cheap amp, 2 speakers, and a sub if your budget allows.
HI,
I am from Portugal, so EU prices.
I am looking to spend around 200 euros and 300 is my top budget at the moment.
Cheers
Meep
Just had a look on OLX, seems like there's plenty of used HiFi gear in Portugal.
Not sure if you'd be up for that, but you could get a lot of bang for your buck that way.
1 - 5 of 5 Posts
