Special Projector Mount
807 Views 4 Replies 3 Participants Last post by  VBDotNetRulz
I am trying to find a projector ceiling mount that can adjust to point down at a table as well as point forwards at a screen. This is the inspiration:
D&D would be pretty amazing with a tabletop projection, but I also want to be able to watch movies on a screen.
Are there any projector mounts that can be adjusted like this?
1 - 5 of 5 Posts
http://audio-etcetera.com/product_in...ucts_id=289437
might do it.
Project sounds fun as all heck. I have a projector myself, they rule.
http://www.mountsandmore.com/Level-M...1-LVM1028.html
something like this seems to be adjustable enough to do the job.
Thanks for the suggestions! The CinemaGear one looks like it will work, but I'm not sure how sturdy it will be. I wish these things had more detailed specs! Some list the maximum tilt while others don't
I also was told by one of my pals I could use a mirror to reflect the projector down onto the tabletop, but it looses some clarity. If all else fails I will go with that.
1 - 5 of 5 Posts
