specify funky custom resolutions?
563 Views 1 Reply 2 Participants Last post by  Coma
Is it possible to set a custom monitor resolution, different from the standard ones in windows?
what I want to do is buy a 19" WS LCD and put it into portrait mode. And I want the resolution to be 1050x1050. I would like the picture to be showing to the bottom (or squished to the right side of the LCD if you were looking at it in landscape mode).
tia
1 - 2 of 2 Posts
Try it with your current monitor. You can't set a resolution per se, but perhaps you can make it so the control panel will restrict the viewport, and pad the rest with black borders.
Though if you just full screened a picture in Picasa or something, it would automatically pad it with black borders accordingly. Maybe you can configure it so the bottom of the picture is always on the bottom.
1 - 2 of 2 Posts
