1 - 20 of 21 Posts
I'm trying to put together a new computer and thinking about OCing it. i am like most people is on a budget. i have around $500 to spend on a CPU,MOBO,RAM,CASE. i am open to suggestion on what parts to buy. I was thinking to get the following for my comp.
CPU-M xp2600+
MOBO-Abit NF7 V2
RAM?
Case?
Can anyone who has build a stable OCing computer please post a list of what parts you use.
thanks soo much.
i would go with a 2500+ mobile instead of the 2600+, as for memory i would go for some OCZ EL pc3200 or corsair xms pc3200, try to get memory with cas 2 latency, for a case i would go with an Aspire x-alien, this comes with a 420 watt psu that should be decent enough to overclock a mobile processor and power the rest of your system, also this case includes 6 fans which should keep your tempuratures down relatively low.
Originally Posted by adas123
well, it depends what size and kind of case u want...
but ram, some sweet 3200 right here, for 1 gig, which is what u wanna get if u can. or this if u only want 512, both are CRAzy overclockers
I think 512x2 of good ram wont fit his budget... Thats more than half of it already...
He's gonna have to go with 256x2, Maybe something like this.
yeah, my second link has 2x256
its cheaper and has better timings
is 2x256 ram better then 1 stick of 512mb.
and why is the xp moblies 2500+ better then the xp 2600+?
thanks
thanks
The 2500+ mobile is not better, it's just that they overclock about the same and the 2500+ is a little bit cheaper.
256x2 is better than a stick of 512 because it will run in dual channel configuration which will boost your memory bandwith a bit.
Discussion Starter · #11 ·
Originally Posted by vtx_
^exactly
With OCing , can you really tell a big differences between 512mb and 1g of ram??
With the xpm 2500+ cpu what type of ram is the best fit, ie PC3200,pc2700 or is the higher the number the better
Discussion Starter · #14 ·
Originally Posted by The Bartender Paradox
only in ram intensive things will you see a diffrence between 512 and 1024.
and 3200 is much better than 2700
im planning on getting the mobile xp 2500+ and the abit NF7 v2. what type and brand of ram would fit this best.
thanks for all the imput .
Discussion Starter · #16 ·
3200 and if your going in a buget then 2x 256
what does it mean when they say lock or unlock xp mobiles 2500+? and how can i tell if my cpu is lock or unlock?
so is all the the xp mobiles cpu unlock or lock?
which board would fit me best if i get the xp 2500+ DFI lanparty or abit NF7 v2?
Discussion Starter · #18 ·
DFI board is better.
DFI "LANPARTY UT nF3 250Gb" NVIDIA nForce3 250GB Chipset Motherboard For AMD Socket 754 CPU -RETAIL
**This item is warranted through the product manufacturer only.
- Specifications -
Supported CPU: AMD Athlon 64 processor
Chipset: nForce3 250Gb
RAM: 3x DIMM Supports DDR266/333/400 Max 3GB
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1x RJ45, 1x 1394, 2x S/PDIF In/Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
SATA/RAID: 2x SATA RAID with NVIDIA RAID 0,1,0+1,JBOD, 2x SATA by Marvell SATA PHY
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: Marvell 88E1111 GbE PHY
Form Factor: ATX
isn't this board for AMD Athlon 64 processor only and i heard it hard to OClock this board it that true or is it all the same?
will this board fit the xp moblies 2500+?
This board WILL NOT fit the mobiles
1 - 20 of 21 Posts
